RFQ: Metler-Toledo to CompactLogix/PV+ integration
gleblanc
Oct 2010
Williamstown, WV
Hi folks. I'm looking for some quotes on integrating a Metler Toledo Ethernet/IP scale into an existing CompactLogix/PanelView Plus control system. Please see the attached PDF for details. Thanks,
Greg
So as I Understand it, you are asking our Communuty of professionals to Quote the work for you? Sweet gig for someone closer.
That's right. I'm the plant engineer for Hino, and one of the things I try to do is hire work out to professionals whenever possible. I've got a background in automation, but not enough hours in the day to complete everything myself. Instead, I try to hire out this work, and keep only the things in-house that make sense (initial design, final testing, installation).
I've posted these a few times over at MrPLC, and had good results, but the traffic there is highly diminished, so I thought this might be another good venue to connect with additional vendors.
Shame. This one is right up my alley; I work with Compact Logix/PVP and Mettler Toledo via Ethernet/IP all the time, but it's a bit of a drive (and a paddle) from here to there.
If you'd be happy with doing it remotely I could have a look?
I have Logix5000 and FactoryTalk Studio (I always leave out parts of that product name), and plenty of practice uploading. I don't have any issues with a remote-only quote, as long as you include some support time to fine-tune any issues we find at implementation time.
Recently I have requested a quote from Magnetek for their Impulse Drives but can't raise a response from them. I've requested a quote FOUR TIMES...
1,078
I have connected ind570 with Allen Bradley logix5561 controller Everything is running fine I want ind570 metler Toledo attributes to be...
1,185
Hi all. Trying calibrate a metler toledo unit, however when doing the span calibration no change is happening when measuring the 4-20ma. Trier a...
1,957
Can some one tell me how to set up password access on this indicator. Thought it would be self explanitory, i have manual but it does not...
2,738
Dear All, I wanna get the data from ind331 indicator(Mettler toledo) to SLC 5/05 CPU via Ethernet Ip using EEM instruction. The CPU=1747-L553...
2,182
