Retain Values in CCW software
dharmik
Apr 2024
Canada
How to retain Values in CCW software?
I am using CCW software and I can not find the Retain function in this software. Not even local or global variable adding section.
please help!
thanks.
It depends on the PLC. The Micro850/870 will automatically retain. But a Micro820/830 you have to check the "Retain" box to keep that data during power loss.
Hello everyone, I am currently having a problem retaining values that i changed. Lets say today i ran my programme and i put my max motor speed...
2,094
hi, i have a lift station project which consists of 2 pumps working in Lead/lag every 7 days or duty switch cycle when one of the pumps have...
2,835
In a data block, if the tag is ticked in the "Retain" column", is it meant to be retained after cycling the power to the PLC? I'm finding that...
744
The PLC in question is a S7-1212C. The PLC will be transportable on a wheeled trolley and used wherever it's needed in the factory. I've been...
1,340
I've got a bunch of tags in my code & there's a column called "Retain" (by default they were all un-ticked) - see pic. "LaserN mm" is a distance...
1,621
