Red Lion
AxiomVerse
Apr 2018
North Dakota
Good Evening Everyone,
I know this is not a Red Lion forum, but I am betting that there are some experts in the community. I recently bought a G310 Red Lion HMI and am trying to communicate with it using Crimson 3.0. Every time I attempt to Verify, Send, Update, or Extract I get a message that says, "Error, the file is incompatible with target device". I downloaded Crimson 2.0 thinking that maybe this device is not compatible with Crimson 3.0. I am able to communicate and make changes to the HMI now using 2.0. I would like use Crimson 3.0 on the HMI and not 2.0. How can I go about doing this?
So far, I have attempted to Extract the .cd2 file and import it into Crimson 3.0 and save the converted file and try to Send that to the HMI. I continue to get the same Error message about the file not being compatible. Can anyone offer some help on how I can use Crimson 3.0 to communicate and configure the HMI?
Thanks,
Axiom
“ERROR – The target device is not compatible with this file.”
• This indicates that the currently open Crimson file is not suited for the device. Click File-Save Conversion to convert to the correct
model.
Thanks Tarik,
I did come across this solution as well and tried it but it did not help. I do not have a lot experience with Red Lion HMIs but is it possible that the HMI is only compatible with 2.0? I purchased this HMI on eBay and it had a configuration on it when I bought it that was a .cd2 file. I was able to extract it using 2.0, but can’t do anything with it in 3.0.
Thanks,
Axiom
If you bought a new one, it is compatible with Crimson 3.0. The issue may be that you have tried to create a project that is for a G310 that is 640x480 but that display is 800x600 (or the other way around). Look on the back of the display and post the model number and I'll help.
Hi All, As a precaution my company has been collecting copies all the HMI and PLC programs. I have recorded copies of most of our sites...
63
While they came up quickly with a fix for the alarm date issue quickly I will have to drive around for a week or so, burning up a lot of fuel...
275
From the Red Lion website, after some customer enquiries in the last week or so... Rev. March 25, 2024 [18:30] Just thought it might help a...
290
How do you install update on Red Lion Crimson ver 3.1. Do I just need to run the exe file on the host server?
125
Hello All, I need the ability to remotely reboot a Red Lion CR3000 HMI. Due to some graphics issues when the database is updated the HMI must be...
245
