Reading from N7:0 in RSLogix 500
HMK007
Apr 2024
Sadiqabad
Hi Everyone,
I am not proficient in RSLogix 500 so I have a question regarding the evaluation of N7:0 data as an input.
So as I understand in the above rung the program is reading data from the N7:0 word
Yes, it is using the 16 bits (or at least some of them), this could be done in two ways, either somewhere else in the program (or an HMI those individual bits are being manipulated i.e. being used as bits rather than a word (i.e. integer value), or again somewhere the word is being manipulated & the originl programmer is taking the individual bits to energise an output.
For example:
setting a value in N7:0 the corresponding bits will be true
so a value of 1 N7:0/0 will be true
Value of 2 N7:0/1 will be true
a value of 3 N7:0/0 & N7:0/1 will be true
A value of 4 N7:0/3 will be true.
A value of 5 N7:0/0 & N7:0/3 will be true.
from the above rung I would say it is unlikely that N7:0 is used as an integer value as any vlue of 2,4,5,6,7,8,10 & so on.
Hello, RSLogix 500, a 4-20ma analog input to PLC is scaled for 0 to 100 psi. It is displayed as 0 to 100 psi on HMI, I want to make sure that for...
3,393
I'm creating an HMI project using Crimson 3.0. I saved my PLC project as a .L5K file and imported that into Crimson. It imported most of the...
1,514
After learning here how to create arrays in RSLogix5000 ver 20.04, I have added some monitoring for a HMI to show 1 of 3 conditions for a bank of...
2,064
Hello everyone, this is my first time asking for help here, so please bear with any problem my english or lack of experience can cause. i have a...
2,707
Hi, if we want to read or set a bit of an integer we can simply do: assume TEST1 is the integer, TEST1.3 := 1; or IF TEST1.4 THEN..... but...
2,498
