Profinet interface with TOX Press
[PL] mk
Apr 2017
src
Hello,
Does anybody have some manuals/documentation regarding profinet communication with TOX PRESS?
The press supplier claims that they do not have any documents, which is strange for me.
Thank you in advance for all your help.
PRESS SPECIFICATION:
Electric press drive type EX-K 010.003.300.000.
Electro mechanical Servo drive with sensor for control of force and displacement.
Electric-Power-Module EX-K 010 with the following features:
* compact
* Speed: 0-300 mm/s
* highly dynamic
* precision guided working rod
* long lifetime due to the use of planetary roller screws
* modular design
* nominal force 10 kN
* max. short term overload capacity of 10 % of nominal value
* high precision force measurement
* force transducer 5-100 % of nominal value
* measurement accuracy <> +/- 0,5 % of nominal value
* max. stroke 300 mm
* displacement repeatability accuracy = +/- 0,01 mm
Hi all, I am a AB guy tying to figure out Siemens' system integration. I have been asked by my company to install new IO for Siemens 315 CPU...
815
Hello, people. Me again. The same project, another problem. The PLC article # is 6ES7 512-1SK01-0AB0. There is only one in the Hardware Catalogue...
1,627
204
Hello Guys, I want to establish profinet communication between siemens plc and my system using python programming. Which python lib can i use to...
432
I want to establish a Profinet network in my production plant to connect multiple devices, including a PLC, HMI, and multiple Profinet-based...
19
736
