Profibus Master Slave (2 s7300 CPU)
Engrtalha
May 2016
Pakistan
18
Experts!
Advice required
S7300 CPU 2 DP 315 Master Slave Profibus.(2 CPU)
In My application I have to send data from Master to slave and slave to master but I can only be able to send data from Master to slave only via Profibus
Program is running ok with 1- Profibus link ok
2-Data is receiving from master to slave non consistent and consistent data 3>4 Bytes
Please advise 1- how to send data from slave to master
Task Attempted:
OB1 Use code for SFC 14-15 & SFC 20 for Slave in same way to transmit data to master but not got any result only master to slave side is working.
Am i doing some mistake in Configuration,Registers or OB1 in M.S Program Code ?o_O
2- Could we transfer real Float values from M-S /vice versa .Currently I have to do round first then move to Word or D-Word in Array DB.
Please find attached snapshot
Thanks!
configuration.jpg 1.jpg DPM-S.jpg Float Value inM_S Config.jpg ob1 code for Master-Slave.jpg
Dose anyone have experience with Beckhoff FC3121 profibus master PCIe card connected to Siemens CP342-5 as a profibus slave? The data retrieved...
17
4,887
Good morning, I am looking to establish a communication between one Profibus master and one Profibus slave. I downloaded the Profibus Master...
58
14,636
Experts! Advice required S7300 CPU 2 DP 315 Master Slave Profibus.(2 CPU) In My application I have to send data from Master to slave and slave...
2,342
Hello Guys, I have s7-315-2 PN/DP with integrated DP. I have no CP module. PLC should be DP master. ON other side there is basler device DECS250...
3,508
Hi, Has anybody setup a system as follows before, Siemens are telling me it should be fine. But I cannot get comms. S7-314C 2PN/DP -...
2,401
