Power flex drive 525 control error during direction test
Chauhanraj
Feb 2024
Pune
I am trying motor startup with pf525 drive by using wizard start over ethernet communication but during direction test it's showing control error and motor is not starting.
You need to inhibit the module in your IO tree. You can't have the processor as owner while using the commissioning wizard.
Thanks for your support.I have tried with CCW software,this time start button option is showing in direction test wizard.I am pressing start button but motor not moving.
I have a doubt on safe torque terminal s1,s2 and s+ . Should I put jumper on these 3 terminal to run motor?
Yes...it comes factory with a red jumper on those three terminals. If the Drive/HIM says Not Enabled then that's the issue. It will say Stopped when the STO is satisfied.
Hi I want to set IP 172.16.27.90 in AB Power Flex 755 drive. I do set the IP by parameters 38-41 with other settings (subnet, gateway) but...
2,532
I'm looking at how to configure a (new to me) Power Flex 753 drive. The part number is as follows and has been specified by a third party...
2,371
i have a problem in the drive 30 kw used with motor 4 pole (1770 rpm ) , and the motor used to run load with pulley ratio 2.3 so the load speed...
4,927
F005 fault appearing on power flex drive plz tell me how to reset
2,384
Dear friends i have to control the speed of 3KW power motor In forward and reverse direction through PLC. PLEASE tell me the all the parameter of...
2,381
