PLC'S From TRIangle research.
I think for their price they pack a nice punch. The only problem I have ever had was with the High Speed Counter connected to a "wire" drawn linear encoder. I kept missing or accumulating counts, I never actually did decide if it was the the way the encoder wrapped around the spring loaded spool or if it was the plc. I am leaning toward the encoder because a simple rotary encoder worked fine.
If anyone has had an experience with wire drawn linear encoder's please post me some of your experiences because I have seen nothing but head aches with them, but then again it definitly could be me. :)
Good PLC for the money. Very robust, I have several working in very tough environments, lots of dust, moisture, heat, and vibration. Somewhat limited on analog in and out, 8 bit out, 10 bit in. But you can connect them to third party analog in and output modules for greater resolution. Very easy to program, a good selection of higher level commands in Basic.
All in all, pretty good for the price. Not a brick type as they are more designed for embedded applications but work good in an industrial enviroments.
Has anyone had any experience with this product? I am impressed that their software provides a PLC simulator to test your code without needing a...
2,960
I'm adding an IAI Gateway with 2 axes connected to it. To an ethernet network on my PLC. So, I think the math is correct on the Input and Output...
185
Hello, im quite new and still learning. I would like to ask is it possible for FATEK PLC to read data value more than 16k? I'm trying to move my...
57
Hi all, looking to model old RR relays in PLC. Does anyone have any SPECIFIC examples on how to model a relay such as a polar relay, slow pickup...
91
HelloI need software to download the program from PLC EH-A28DRP from an old machine whose manufacturer does not exist. It may be Ladder Editor for...
102
