PLC State Machines / Sequences
I'd forgotten about the integer-as-state-identifier method. That works, but not always as well as you'd like. It works wonders in systems where each state is mutually exlusive. And of course, you can represent a system with various non-exclusive states by expanding the number of exclusive ones to involve all possible combinations, but that can get very messy and complex if your dealing with a number of states that can go on and off independant of a certain process (such as say, a washing machine that has to control the water temp by a simple "if too cold, heat up, if too hot, turn heater off" scenario, along with various the usual sequence of events). Of course, you could go for a hybred approach and have the heater control and wash cycle control have their own independant process controlling variables as well.
This is a good example of how there are plenty of different ways to go about this sort of thing, davidd31415.
AB Phase State Manager
For Allen Bradley take a look at these 2 manuals. They offer quite a bit of help in understanding SFC and Phase State programming. They can be found at the Allen Bradley site without a tech-connect contract.
SFC 1756-PM006B-en-p
Phase State LOGIX-um001A-en-p
I have only run into SFC a couple of times on a Direct Logic PLC. I was amazed how quickly I could understand how the equipment was programmed to operate.
I have not had the pleasure of using the AB Phase State programming, but had planned to use this method on a project that has since been cancelled. I really think that there is a lot of power in this method because it forces one to think in terms equipment in terms of normal states; stopped, running, idle, or faulted and the transitional actions needed to move from one state to the next. I see too many pure ladder logic routines that are poorly organized where it is difficult to key in on an equipment state and what leads to a state transition. At the very least this method looks like it forces a logical organization.
Even if you decide not to use Phase State programming, I believe using the phase state model is an excellent tool to use when developing a new project. Most processes and tools fall very neatly into this model.
A CIP request for the Identity class (0x01), Instance (0x01), yields the State in Attribute 8 (0x03 as Operational, for eg.) in its response. Is...
475
Dear forum, I have earlier worked with RSLogix 5000 and I remember there was a function in the software that made it possible to save the current...
2,151
Hi all, I was wondering if there’s a automatic tool that can convert a PLC written in ST, FBD, IL to state machine diagram? Thc
1,471
Is there a way to know which is the primary and secondary chassis through gsv? I have read that "PhysicalChassis" (Chassis A/Chassis B) is an...
2,246
Hi, ive recently just started studying Plcs as a topic within my engineering course. and im finding it extremely hard to find information about...
5,400
