pb32 covert to factorytalk
stu
Aug 2005
England
785
hi guys
im having an issues converting a panelview 600 to panelview plus 600 ?
I have done 2 hmi program conversion on factorytalk studio but there is one that gives me a error when it starts converting? the error is unable to retrieve project information the server threw an exception ?
any ideas
im using a 32 bit win 7 laptop , factorytalk 5.1 .
I have looked on line and found something that said to make sure that the external fonts is in
C:\program files\Allen-Bradley\PBEX\Fonts
It's the same on the other screen I've done?
Lost any ideas would help
thanks stu
Well, I searched for pbex and found this thread. While trying to import a PB32 file into FT View ME it prompted me for admin right then error out on "Failed to Open project: xxx.pba"
older versions of panelbuilder may not convert.
do you know what release the panelview application was created on?
if you have the older software version, import the app and then do an upgrade to the next version (sorry, I cannot remember what the increment is.
the ugrade to 3.83.01 - last release.
you have to do the middle conversion, sorry.
james
I had this pop up today on a PanelBuilder, PanelView 550. I can not find it in the PB messages any where. I pressed any key like it said. Every...
2,655
On PB32, PV 600 I want to add a screen for a analog tempurature trend. How does the Graphic Indicators-linear set up work? Where do I add the tag...
1,208
Hello, I am hoping for some help with setting up a .mer. I will try and give as much detail as possible, thanks. I am trying to convert a .pba...
2,333
Hi Friends ! I'm having a little challenge here, I'm almost done in my conversion project from panelBuilder to Factory Talk. I really need a...
1,586
Hi Friends! Who could just show me kindness by giving me a full idea on solving this error below: ''Tag es temp: Bit Array tags are not...
2,243
