Passing Parameters twice
Lisa3003Lisa
Aug 2023
Richmond
I'm using FactoryTalk ME version 13. I'm aware how to pass a parameter file once, but I was wondering if it is possible to do it twice.
Scenario:
I have multiple I/O racks, and each rack has a different number of slots. My idea was to have a Go To button for each rack with a parameter list with {[PLC]Rack1}, {[PLC]Rack2}, etc. All of those Go To buttons would go to the same display, which would have a Go To button for each slot that the selected rack has. Within those slot Go To buttons I wanted to put another parameter list, like {[PLC]#1.Slot1} or #1.{[PLC]Slot1}.
However, I'm not sure if it is possible as I have not had a success.
Are you using parameter files or simply a parameter list?
I have tried and failed to use parameter files in this way without involving the Global Connections settings of the HMI and a PLC. You do have the ability to "build" a parameter file name in a PLC as a literal string and read it with the HMI under Global Connections\Display\Parameter File. If you designate a string tag in this connection, the HMI will attempt to load a parameter file whose name matches the contents of this tag whenever it changes/refreshes the screen. If you do this, you could opt for a set of interlocked buttons instead of GoTo buttons that change a numerical reference in the PLC, which triggers a new parameter file name to be built, and triggers a screen change that implements the new parameter file.
Hopefully this helps. I spent a fair amount of time on the topic of parameters in FTView a while back and found the FTView Studio User Manual to be quite helpful. If you'd like an example of what I described PM me and I'll see if I can pare down one of my recent projects and send it over.
Cheers.
Parameter passing is possible with both parameter files or parameter list to pass parameters from a display to other displays that are opened from that display
Have a look in the FTView Studio ME User Manual in the Use parameters and global objects chapter, Parameter passing topic for guidance.
If I am understanding you correctly, you want to open a display and in doing so calling a parameter file to display your rack options based off of the goto display. Which will use said rack number to control other parameters when opening another display? I recently did something similar with a pop up and list for bypassing sensors on a machine. (our crib is not very good as keeping things stocked) What I did was use a Piloted list in the first screen, for my display visibility, then referenced that same value for the next parameter.
So for your example: piloted list selector, set your states to their corresponding number i.e. state1 = 1 state2 = 2
Value = {[PLC]RackDisplayTag}
Indicator = {#1}
Remote Access = 1 (I actually had to make and Always_On tag in the PLC and set it to a constant of 1)
Parameter file: #1 = Numbers[XX] However big of an array you need then set each diminsion to it's corresponding number i.e Numbers[1] = 1
So when you open the first display it calls that parameter file sets {[PLC]RackDisplayTag} to whichever value that you chose with the parameter file which you can then use for your visibility.
Then for your next goto display call another parameter that is: #1 = {[PLC]RackDisplayTag}
#2 = Numbers[XX]
And do the same thing over except for Slot display instead.
(Note: not sure if I articulated this all that well)
I'm developing a program in FTView ME for a machine that has three independent axes of motion, each controlled by an old pneumatic proportional...
2,853
I've developed an AOI for our facility, and it appears to be working well for what I need it to do. (Analog alarm for multiple alarm setpoints)...
2,276
I am trying to create a single routine that can control multiple pumps. My pump tags are all different data types for each pump, i.e. bool, real...
1,514
Bear with me as I try to explain what I need to happen. I'm working with FTView SE 6. I have successfully created a screen that has multiple page...
4,143
I am trying to create a common "motor control" subroutine in RSLogix5. I would then "jsr" with parameters once for each motor. No problem so far...
9,558
