PanelView 5000 screen number / control / actions ?
Ken Roach
Apr 2002
Seattle, WA
17,494
I'm doing my first PanelView 5000 application with Logix View Designer v8, and am of course jumping in headfirst.
One thing I don't find is a way to tell in the PLC what Screen is currently open on the terminal. There doesn't appear to be a number associated with each Screen, or a "Global Connections" sort of feature like exited with FTView ME.
In addition, I don't see any Events that execute when a Screen opens or closes. I see that just touching the screen can execute an Event, without touching any touch or key enabled objects on the screen.
And of course I don't find a way to trigger Screen navigation changes, or to use the PLC to trigger a pop-up window.
Does anyone on the Forum have experience with the View Designer platform and these sort of features ?
So as not to make this a whiny post: the HMIBC Button Control fast I/O feature is fantastic and easy to use. I am doing some precise jog work and the touchscreen makes it easy to program my own tap or hold timing logic.
I did a my own screen number with the navigation button by using an Event.
It was ugly but it worked. The VPN setting needs to be triggered on startup. There is a KB that shows you how to hide an Event in the banner.
I'm looking at a CSV data logger and going to see if the PV5000 will do it. If not I'm going RedLion
Yeah... Welcome to short sighted RA, I don't think I have programmed any other HMI that did not have a tag linked to the screen number lol.
Tarik, those are fantastic resources, thank you ! I didn't even know about Project Events until now.
I'm on a tight timeline and would have found this stuff eventually, but often this forum is faster and more relevant than control-F or sit-down-and-read-it-all-tonight.
Jeff, those are some great ideas about hiding things in the banner. I've definitely done similar stuff on a DIY basis in FTView ME, and the PV5000 makes it so much easier to use a banner display.
Anyone using View Designer found a good way to display the screen name on the banner? I have tried using the local tag CurrentScreenName but...
2,374
This may be something obvious that I could learn if I sat down to understand the topic in detail with tutorials and manuals. But sometimes it's...
139
I want to to communicate a panelview plus with an RSLogix emulate 5000 and I know that this is not possible by RSLinx Enterprise, how can I do it...
2,763
Hello everyone, My name is Randy and I am an electrician/instrument tech. I have limited experience with PLC programming, and any experience I do...
3,206
Good afternoon all, I am attempting to get a panelview standard 1000e too communicate completely with a 1756-L83E through a 1756-DHRIO card and...
2,886
