Panel numbering conventions/standards
Von
Jul 2006
Florida
50
Hello all,
I have had to add some new panels recently and can't really make any sense of the numbering method used previously and would like to correct this. In one case a panel, FP-1, would be the panel containing the plc but then another panel containing some magmeter controllers or other transmitters connected to the plc would be labelled 3-1-2. I cant find panel 3-1-1 or 2-x-x etc. There are other examples but that probaly wouldn't help. I'm wondering if there is a standard or other conventions y'all use.
Thanks in advance...Von.
Von said:
Hello all,
we normally use YYMM### as panel numbering, where YY is year of decade, MM is month and ### is incremental # of panel built that month
Ian
I HAVE B&R POWEL PANEL 400 HMI. THE ISSUE IS HMI NOT BOOTING, DISPLY SHOWING CONTIUESLY (ATTEMPTING TO A BOOT HARD DRIVE....)
60
Is there anyone who can help me regarding this HMI is missing the choices when I make a new Device in TIA. Only 7" Display above are the choices...
108
I have a German programed ME program. I want to know what tag in the PLC a latched button turns on. However when I open up the tag properties I...
231
We are considering dropping our UL membership because most of our customers do not care if we are a 508A shop. However, there may be times when a...
424
Hello, I need to create an automatic transfer panel that connects to the generator when the mains power is cut. I can draw up to 60kW and draw up...
102
