Omron CJ2m cpu33 - reading codes
James Mcquade
Oct 2007
Nashville, Tennessee area
3,686
Hi all,
i have 8 CJ2m plc units that show different numbers on the plc display and i am stuck on reading the info.
my unit has an ip address of let's say 192.168.1.7
the display shows ip then 07 after a couple of seconds, 07 is the ip address
then it shows Er and after a couple of seconds d5
then is shows IP and then 64 after a couple of seconds.
the process repeats. this is the same for all units, just not the same numbers.
How do you read this code?
thanks in advance,
james
Hi James,
D5 is a non-existent target on a tag datalink. You will need to use network configurator to look at the ethernet/ip configuration.
Or it is a target that is disconnected, powered off or not working. It is normally remote I/O that is missing or not working that is in the CPU Ethernet IP table - yesd - have a look with network configurator. Upload from the CPU with a USB cable.
Just for further clarity, the D5 followed by IP 68 is the missing or un-connected node. The 68 is Hex so the IP would end in 104
Hello, someone have an example of an comunication between an Omron CJ2M CPU33 with FINS TCP to PC? Thanks for help
1,392
Hello Someone know an Function Block or example code for Fins TCP/IP or UDP working for CJ2M CPU33? Thanks for help
1,222
Hello Its possible to comunicate with an Omron PLC CJ2M CPU33 over TCP/IP with an PC software to test this connection, like SocketTester or...
2,104
Hi every1, hope all going well. I recently joined this website and this is my first post here. So actually i have a PLC OMRON make SYSMAC Model...
2,660
When looking at instructions from help, instruction reference,CJ/CS. I see flags area. how can i tell what these are? Like in BCNT. Top Says...
2,731
