Oee
abwiz
Nov 2005
PA
196
I have a piece of equipment that shows machine efficiency calculations. They use a standard formula that divides GoodParts/Operating Time.
I have always used OEE so I am wondering if anyone else uses this.
Hmmm..!!!
Hmmm..!!!
I use OEE. You need to seperate, Availability/quality/performance to know where you need to improve.
We have several systems that determine OEE.
I agree with NED. There are several parameters.
Loading - Schedule time of operation.
Performance - Operation speeds against designed target speeds.
Availability - Time that operation was available to operate.
Quality - Acceptable produced Units.
The product i would recommend is called AMPLA. What works well is that you have down time analysis within it. So you can define additional parameters when there is a halt in production.
The downtime analysis is automated so instead of an 'operator' defining what the cause of the downtime is the system reports on this.
This streamlines the operation and makes it easy to identify problematic areas associated with the operations.
Rheinhardt
Hi, I am trying to implement a OEE SCADA. I would like to know how to calculate realtime OEE any one has experience on this please reply Regards...
2,271
Hello all, My company is looking to begin looking at OEE software that would give managers, etc a dashboard to look at machine efficiency. I'm...
2,690
Hi, Does anyone know if there is a "OEE" template availble for Intouch? Instead of building it up from scratch, I thought it was worth a shot...
1,184
Oee
Hi, Has anyone used a PLC to cater towards OEE or TEEP? Can I get some pointers? Thanks Ron
1,526
Hi all I am beginning a project at gathering OEE data from 2 production lines at first and if successful to more lines. The main things I want...
2,872
