Modicon M580 Modbus Register Mapping
iotguy
Aug 2023
UK
Hi all,
I'm really new to this. I need to export the Modbus register mapping from a Modicon M580 through Control Expert for the registers that will be accessed by an external application but I cannot see an obvious way to do this. Is this possible?
In control expert you can sort the variable section of the data editor by the address column. Then click on the first tag with a register that you want to export then shift + select to the last one in the range you want (the tags will be highlighted black after this). Right click and choose export selected. Save file with dialog that pops up and I recommend changing the file type it exports to from .XSY to .TXT for what you are trying to do.
Thanks Jim,
I'm seeing more registers that are being used than what is mapped to variables. I'm assuming not everything needs to be mapped to a variable and then each needs to be exported individually?
Thanks Jim, if not every variable has to be mapped to an address in Control Expert that probably explains it.
we use M580 which have an Modbus RTU port correct if iam wrong now should i have to read input data from ab micrologix through read var block and...
1,866
We are now planning to upgrade from Quantum 140CPU11303 to Modicon M580. The software protect was written by Proworx NxT (.DCF). Is it possible...
1,014
Hi, Does anyone know if programming a Modicon M580 is basically the same format as an M340? Also do they use the same software package? Thanks...
1,785
I need to convert some Siemens PLC logic using Siemens TIA V16 to Modicon M580 logic. Is there a tool out there that will get me started? How...
2,706
How do you go about implementing, on the M580 PLC, how many days, hours, minutes before a predefine event in the future? The RRTC_DT yields the...
1,829
