Modbus RTU in Schneider M221
cheahcc
Nov 2014
ipoh
Halo Guys,
I new to Schneider M221, I need your help.
I have 1 project with M221 connected to 18 units of modbus devices. I can't use Modbus IOScanner. So, need to use Read_Var function block.
These modbus devices have: Temperature Controllers, Flowmeters & Power Meter.
Temperature Controller have 2 different modbus registers (SV & PV),
Flowmeters have 2 different modbus registers (flow rate & totalizer),
Power meter have 4-5 modbus registers (total power, factor, Voltage, Current)
Actually I not familiar to do the sequential programming on "Read_Var" function base on all these devices.
I don't know how to do the Read_Var programming on changing the Modbus ID, FirstObj, Qty & IndexData by gather the info/value from all devices 1 by 1.
Hello everyone! Posting from Argentina as I don't know what else to do. For a bit of context, I am using an Allen-Bradley Micro850 PLC and five...
10,536
Whilst I'm waiting for the PLC to turn up next week, I thought I'd see if anyone here can answer the question/confirm my thoughts. I am...
3,794
Dear All, i am trying to connect Danfoss inverter with s7 200 cpu 226.but microwin shows following error at DATA Ptr.i assigned different VB...
63
I'm trying to control a device via MODBUS RTU and the ModbusRtuMasterV2_PcCOM in Twincat 3. I've configured a device with the right com port and...
290
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
291
