Modbus RTU Chinese Temperature PID controller to Wincc 7xx
Judge Muntu
Sep 2023
Kafue, Lusaka
I have an old Chinese Temperature PID controller XMT 8038c2kp that am able to send and receive requests via Modbus poll test center in this format 81 81 52 00 00 00 53 00...and response is coming back as 9A 42 00 00 00 11 AA 06 , **42 9A** ** which is 1705, my question is I have kepware and wincc7.5 I want to connect and create SCADA interface for furnance, anyone with how I can get to my goal
Dear All, i am trying to connect Danfoss inverter with s7 200 cpu 226.but microwin shows following error at DATA Ptr.i assigned different VB...
66
I'm trying to control a device via MODBUS RTU and the ModbusRtuMasterV2_PcCOM in Twincat 3. I've configured a device with the right com port and...
303
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
302
Hi, I'm having an issue with a mircologix not transmitting out. The current setup is a mircologix 1400 connected to a Guardian 100 Radio...
139
If a device has Modbus RTU over serial and Modbus RTO over TCP and Modbus TCP then there is a difference between Modbus RTU over TCP vs Modbus TCP...
612
