Mitsubishi PLC - CCLink I/O configuration
rajivs1107
Feb 2010
Delhi
25
friends,
I am using Q06H CPU, and CClink QJ61BT11N . I want to add a servo drive of DYNASERV that uses 64 I/O using CClink . in my CPU 1 to 34 stations are already configured . i want to use station number 35 and 36 (32 remote i/o to each) for this DYNASERV . I set it in parameter but if i do loop test it only shows station number 35 but doesn't show station number 36 when i do loop test . please help how to configure this servo drive .
Unfortunately there isn't much help here with the Mitsubishi stuff, not many of us know it. Sorry. I've posted a couple questions that have gone unanswered as well. Your best bet is to contact a Mitsubishi distributor in your area.
Hello, I have a Mitsubishi FX3G 14M PLC and a E615 HMI from Mitsubishi/Beijer. I'm using GXWorks 2 to do the programming and I have no problem...
163
HOW to communicate with OPTIX and Mitsubishi's Q Series PLC?? PLEASE HELP ME
99
Hi , Where i can find Mitsubishi PLC Card end of line & replacement model details. i am looking for Q02CPU replacement model. Please advice. thanks
189
I have Toyopuc PLC PC10G-CPU and some communication modules of it. With this modules I'm able to connect with Ethernet, Ethernet/IP, FLnet, FRMT...
106
Hi all, anyone does have experience in Gx Works 2? Currently I having an issue which is when certain device added from MELSOFT Navigator and...
143
