Mitsubishi MTA-10 and FXO-14MR-ES/UL
cannigia
Apr 2006
Elk Grove Village, IL
Hi! everybody,
I have a Mitsubishi MTA-10 interface and FXO-14MR-ES/UL PLC. In the MTA-10 interface, there are 6 keys and one of the key doesn't work. I have to push many times to input choice through that key. The other 5 keys work fine.
Between the PLC and interface, there is 8 pin mini din cable. I changed this cable but still get the same key doesn't work.
Could any one tell me if I can bypass this key? Because I can't find the Mitsubishi MTA-10 anywhere.
I have a picture for this interface and the green key doesn't work.
You probably can't bypass the green key unless you can change the program in the MTA-10, and even then it would probably be awkward.
The MTA-10 was made for Mitsubishsi by Beijers, they are located in the Chicago area I believe. The unit has been obsolete for a few years.
You could get the unit repaired either by Mitsubishi or perhaps by Beijers (Cimrex)
Good Luck.
Cannigia
just ran a cross a MTA-10 on E-bay #8792978707 starting at $10. That looks like a replacement fix for a little money.
Good luck!
JerryMac
I have a plc Mitsubishi FXOS-14MR-ES and I would like to know if I can use the interface MTA-100 to programing.thank you guys. MTA-100...
1,656
Anybody ever connect to Mitsi ACPU via an MTA HMI? If so what is the trick to setting up the comms?
1,611
Hi All, I have been tasked with trying to find the programming software for a Mitsubishi MTA 250 HMI. It would be great to find a manual for this...
4,580
I am in need of someone to suck the programs out of both a Mitsu Plc and the MTA-250. I am trying to purchase a machine but before i go through...
1,571
I'm looking for imfor on an old MTA10 I have. I would like to re-program it. But so far I have been unable to locate any software or interface...
3,889
