Mitsubishi HMI
That doesn't look like a standard HMI error message, so I guess that somebody programmed it in. If this is on a system that has been working correctly I would look for a phase sequence relay, I would guess that it has gone faulty. If it is a new system, I would change the phase sequence because the panel doesn't like it the way it is now. Phase sequence is typically important if you have 3 phase motors, they try to run backwards if the phases are reversed.
Thanks for BryanG. I will check the phase to the motor. the motor is controller by servo driver. But It happens when I power up the HMI & PLC. the whole machine do not run yet. I am a new guy for Mitsubishi PLC and HMI. It is big issue to me because I can not go through next step.
Not just the phase to the motor, but the phases to the box. It could be that you have lost one phase on the supply. Always start checking where the power comes in.
Hello, I have a Mitsubishi FX3G 14M PLC and a E615 HMI from Mitsubishi/Beijer. I'm using GXWorks 2 to do the programming and I have no problem...
169
hi all i am new here i have a mitsubishi smart touch hmi i.e ms-60t-pe but i cannot find a software to edit and download a program in it any help...
188
Hi, Anyone know Mitsubishi PLC ? I have a A960GOT HMI. When I power it up, It shows "system is wired incorrectly! please change phase sequence!"...
391
Hello Everyone, I am hoping someone can point me in the right direction. I have a Mitsubishi PLC FX3u connected to an old ProFace GP2500 HMI...
1,593
I am trying to get a Mitsubishi GT2715 HMI to read and write from a Eurotherm 3508 controller using 4 Wire RS485 Mobus RTU communications. The...
1,323
