Mitsubishi - FX3U + FX3U-USB-MB + FX3U-485ADP-MB - Modbus configuration - Paramètres
Gael Boucekkine
Supporting Member
Mar 2024
Arras
Bonjour,
Je n'ai pas de communication modbus RTU vis la configuration ci-dessus.
J'ai essayé les deux mode ch1 et ch2 mais rien ne fonctionne.
Avec le même programme, sur un FX3G + FX3G-CNV-BD + FX3U-485ADP-MB, çà fonctionne avec les registres D8400=H1097 (19200bauds, 8its, even), D8401=1(maitre).
Des idées, ou une solution.
Merci beaucoup.
Good morning,
I don't have modbus RTU communication with the above configuration.
I tried both ch1 and ch2 modes but nothing works.
With the same program, on an FX3G + FX3G-CNV-BD + FX3U-485ADP-MB, it works with registers D8400=H1097 (19200 bauds, 8its, even), D8401=1 (master).
Ideas, or a solution.
Thank you so much.
Gael.
  • PES_NESTLE_V00.zip
Hello everyone; I have Mitsubishi PLC FX3U 32M in hydropower plant governor, an error message popped up when a technician was working on an...
383
hmi keeps saying "insufficient sensor failed" after the machine runs for 60 seconds. its a fx3u-48m PLC. The plc is not giving any errors or...
2,278
Hello All, I have been trolling through the Proface documentation to find an answer, but I read conflicting information. We have a...
3,940
Hi All, I am looking to install a Red Lion CR3000 HMI and connect it to a Mitsubishi FX3u 64M PLC via Serial. I cannot find confirmation on...
2,854
Hello, I have an FX3u-16MR/ES, FX3u-ENET (version 1.0), using GX Works2 Version 1.596W (Trial version). Using FX Configurator-EN...
4,993
