Micrologix 1500 LSP Series A Firmware upgrade fail DTL_E_FAIL I/O
zephxiii
Apr 2013
Indiana
Hello, I have a 1764 1500 LSP Series A that keeps failing with DTL_E_FAIL I/O error. Searching around it seems there's a weird issue specifically with series A and latest firmware updates?
I was able to update a 1500 LRP Series C no problem at all on this same system.
I started with firmware update 14, then tried 11.
I saw on another thread that ControlFlash 8.0 fixed the issue for someone but that one I can't find. V12 is currently installed on the machine.
Any ideas?
So I figured out that I had to close RSLinx before attempting to flash the 1500 LSP Series A CPU otherwise it would fail every time. Once it was closed and I tried to flash it worked perfectly.
This was not an issue when I updated firmware on another 1500 LRP that already had Series C on it. I guess this is specific to Series A.
Problem solved.
Good Day i Have Micrologix 1500 LSP, and I want to get data from plc and send it through Modbus RTU slave; I have only ch0 on that plc I Order...
955
Hello, I want to use the RTC function files in my program to turn on a certain output at a certain time, but I am having trouble setting the...
3,970
Battery is bad. Broke + terminal removing battery. Does this unit have an EEPROM available for it? Currently we have to reload program every...
2,281
I apologize for this post as it may be a simple oversight on my part. I have 2 AB Micrologix 1500 LSP PLC's and 1 Micrologix 1510 LRP. I'm using...
6,096
Good morning Everyone, I replaced a micrologix 1500 1764-lsp processor this morning and downloaded the program, but when I try to put the...
3,629
