micrologix 1500 LRP read/write communication
suboliu
Oct 2010
windsor
266
Hello everybody
I am new. hope get some help on here.
I have a micrologix 1500 Lrp and a marking device. I would like to use Ethernet to communication. I use 1761-net-eni interface to connect 1500 and marking device. I want to send string to marking device to print letters through Ethernet. and get string from marking device by Ethernet.
my question is:
1. how to configure plc IP address? in Rslogix500 its channel 0 and 1 hasn't Ethernet.
2. what kind instruction can write and read from/to marking device?
if I use MSG to read string from marking device, it said ERROR:local address may only be a ST file type 485CIF write command. which instruction can I use to read string? and why I can't use ST file as target address? if I want to read string from marking device, what file should I use?
see my screenshot.
3. what is difference AWT and MSG instruction?
any suggestion welcome.
Does anyone have an example program using control techniques EN drives?RSLogix 500 ver 6.3, to be put in the upload section on here. I’m wanting...
1,375
I have searched for hours trying to find an answer in the threads some seem to come close to my issue but not exact. I am trying to communicate...
17
8,107
I can't believe I would need assistance on this issue, didn't think this would be a problem. Anyways, I just bought a Micrologix 1500 LRP plc in...
7,197
Hi, Need to communicate Allen Bradley Micrologix 1764 LRP with my Laptop to read data (coil & holding registers) via modbus rtu protocol using...
5,420
I am trying to set up a MSG read in a Micrologix 1500 LRP series C to read data from a Compactlogix L32E via a NET ENI series D. I have...
8,538
