Micro800 CCW Modbus Mapping
ecampos
Jan 2016
PA
24
Got a 2080-LC30-24QWB with 2080-SERIALISOL card hooked up to a Modbus slave device. MSG_MODBUS instructions are working fine. I am trying to set up Modbus Mapping but it does not seem to be working.
For example: when I read from register 30002 using a MSG_MODBUS instruction I get some valid data. When I set up a Modbus map entry with variable name = x and address = 30002 I get nothing. x is always = 0
I have been reading every plctalk.net thread, AB technote, and manual I can find but I'm not sure what I am missing here. Can anyone shed some light? Does Modbus mapping actually work with the SERIALISOL card or is this only for the built in serial port?
Regards
I'm still a beginner when it comes to PLC's programming in general but I've had a fair bit of experience with SLC 500's and micrologix, but I've...
1,534
I've decided to give the Micro800/CCW world a go, so would appreciate a steer towards a few background articles (not starter). I have a lot of...
1,033
Hi there, I have a small heating system with a micro 830 PLC to assist with the learning process of automation and PLC's etc. The system is a...
8,340
I've got a machine builder wanting to use the AB Micro800 series for an upcoming job. I realize that from a machine builders perspective, the low...
5,607
