Micro 1400 upload error
rankhornjp
Dec 2008
Georgia
241
Error: "Program in processor has changed causing offline state. Do you want to upload?"
RSLogix500 V8.10
Micrologix 1400
Customer wants to add an I/O card to their PLC. They don't have a copy of the program. I can see the PLC in RSLinx and can upload from it. However, once I upload, I get the above error. Then it just loops over and over; upload, error, "Do you want to upload?", yes, upload, error.....
Any idea how to fix this?
To answer usual question I found while researching this:
Yes I'm trying to UPLOAD. i need to get the project from the PLC to the PC.
No, I don't make any edits to the program prior to going online
Seems I remember there may have been a bug or compatibility issues with certain versions of RSLogix 500 working with certain versions of Micrologix.
Maybe someone with more patience for the Rockwell Knowledgebase can dig deeper.
Can you try a newer version of RSLogix?
So I googled the first three lines of your first post and found a link to Answer ID 5970. It requires Techconnect access. But it says you need version 8.30 or newer to connect to a Micrologix 1400 series B.
Hi! Last few I've been trying to send message from MicroLogix 1400 to Micro 850. Unfortunately every time I failed :banghead:. Did someone tried...
3,246
Hello, There was a mix up in information on some redeployed equipment and two of the micro 1400's that came in were hooked to 120v when they...
1,988
I am trying to exchange data (N registers) to and from a Control Logix PLC. I am programming the messages in the Control Logix program, to...
2,211
Does the 1100 only have 1 high speed counter, but it can have multiple inputs? And so then the 1400 has 6 HSC and you have a choice of multiple...
1,730
Hi guys, I need to add 2 x 1769-IF4 and 1 x 1769 OW16 output card into an existing Micro 1400 Series A PLC. It has already has 3 expansion...
2,899
