MELSEC A RS422 (25pin) <> iQR C24 Serial RS232 (9pin) - Simple PLC Communication
jenas6423
Mar 2020
KL
Communication from a MELSEC-A Series CPU (RS-422 – DB 25 Pin) with R Series CPU C24 Serial Module (RS-232 – DB 9 Pin).
I would like to request for support for the Wiring Diagram of the RS-232/RS-422 conversion cable. So far only Diatrend DAFXIH-CABV that works. But I couldnt find any wiring diagram for DAFXIH-CABV.
Due to high cost of DAFXIH-CABV, I am looking for alternatives, I am testing with standard RS422 <> RS232 converter in the market, but all failed to communicate, can anyone help?
Reference:
https://www.diatrend.com/IFcable/9p/dafxih-cabv.php#kanren
https://dl.mitsubishielectric.com/dl/fa/document/manual/plc/sh081251eng/sh081251engk.pdf
Page: 119 (Section 6.1)
Please advise.
Appreciate your help
Just google SC09 cable pinout that gives you the pinout of the 422 & 232 but may require the 232 pins 2&3 swapping.
Hi @parky,
Thank you for your reply.
We have tried SC09, and it was unable to communicate between MELSEC A and C24 RS232 port with the same setting as Diatrend DAFXIH-CABV.
Do you mean we have to swap pin 2&3 for RS232 end of SC09?
Why is that and how do we do that?
Please advise.
Appreciate your help.
Thank you
It was just a suggestion to build one using some other 422 unit, Swapping pins 2 &3 was just a sugestion as some equipment uses a crossover (null modem) some use strait through, used to be able to get crossover adapters but as 232 is not used much now they could be hard to find.
I built my own just back to back 9 pin connectors but wired 2 & 3 pins crossed over so you have a 9 pin plug & 9 pin socket wired pin to pin but cross over 2 & 3. I used to use it for the Beijers (Mitsubishi) HMI's as the original programming lead changed when they went from the older Mac series to the E series.
Hi @parky,
I have tried to solder a crossover RS232 cable switching both pin 2&3 and 7&8. But unfortunately, didnt get it to work as well.
Is there any other troubleshooting method we can use?
Appreciate ur advice.
Thank you.
Regards.
Jenas
I want to communicate my Q series PLC with Factory IO using GX works 2 software, I want to use modbus as server and the ips are as follows plc...
88
Hi everyone, I have a small project for an industrial site entry gate system. It's running on an old Melsec PLC, and I have a new Shihlin PLC...
168
Anyone have access to Melsec Medoc plus 2.31a that can either open a file (.pcd zipped in link below) and send a PDF/screenshot of the ladder, or...
400
Hello! First time poster and a big PLC newbie so I am looking for some backup here. I have an old Mitsubishi FX-48MR that lost its program...
554
Hi I have a Melsec FX1S-20MR, which has been programmed. I would like to copy the program to a new FX1S-20MR? What are the possible ways to do...
652
