Market Research
Ernie123
May 2013
CT
Hello,
My company is in the process of designing a temperature transmitter line and we are trying to do some market research. Any input you may have will be greatly appreciated.
Where do you go when you need a product for temperature?
What industry are you in?
What do you wish your PLC manufacturer would do that they are not doing? OR if they do something you like, what is it?
Is cost a huge component in your decision making?
THANK YOU!
One expects a configurable range TT nowadays, so the question comes up as to what is needed to change the range. Is the TT itself $100 or $150 and the software and cable for configuring the unit $500? I avoid those like the plague. PACTware is gaining acceptance as an easily available HART configuration tool, although the mfg has to provide the DTM file for their product.
The advent of widespread USB and the disappearance of RS-232 serial ports on PCs would make a USB comm connection with a standard USB 'printer' cable a nifty idea. I don't know if USB is technically feasible on a loop powered device, though.
Tiny ring terminals, in addition to the terminal screws, to which one can connect spring clip test probes or spring clip HART probes or spring clip DC power wires when configuring the unit would be an inexpensive, but neat feature for those who test and configure, to avoid the necessity for connecting to screw terminals for test or config.
A diode between a couple of "test" terminals for reading the 4-20mA without having to break into the circuit is a sign of a 'better quality' TT.
I prefer terminal screws with square washers that can't rotate against a barrier because I only have two hands and round washers tend to let the wire slip out as the washer tightens, requiring the three hands of a Martian.
If you go HART, you might consider
- reporting CJ temp as the 2nd variable
- doing thermocouple drift analysis and reporting the T/C condition as a HART variable. This technology deserves wider use.
A flat, non-glossy surface onto which the range could be written would be handy.
Cheap and convenient DIN rail mounting is a necessity, as is DIN Form B head mounting dimensions.
The sensor market is fragmented amongst different type T/Cs and 100ohm Pt RTDs.
I personally won't use a non-isolated TT, life's too short to deal with ground loops and common mode. But I suspect that non-isolated out sell isolated models because of the price difference.
It's been over a decade since Bosch Rexroth announced their SIL2 joystick for vehicles using multiple axes and interfacing with CAN/J1939...
123
https://www.hackster.io/news/arduino-unveils-the-opta-its-first-micro-plc-for-the-industrial-internet-of-things-d97f1d6b868a...
32
10,228
Good Evening , I took notice that the majority of the gearboxes we have in our plant are SEW Eurodrive . I started wondering , of all the...
4,221
Hi, Just curious to how the job market is for controls engineers in the UK at the moment? I'm not seeing many jobs advertised, and wondering if...
2,382
I thought the forum users would find this of interest. There were a few surprises...
2,014
