Logix tag based alarms with PlantPax alarm faceplates
jt__
Jul 2014
Canada
Hello,
I am upgrading some custom AOI's for a customer that was using plantpax 3.5 they are moving to Pax v5. In their old AOI's they were using the P_Alarm block with the standard Pax alarm faceplates (ie, they could open the rockwell alarm faceplates from their custom AOI faceplate - very simialr to how standard plant pax faceplates work.)
I am trying to convert the P_Alarm to tag based alarms inside the AOI and I would like to use the rockwell alarm faceplates with these custom AOI alarms, similar to how they were doing it with version 3.5. Problem is I am getting many expression errors when opening the alarm faceplate such as: Expression contains a tag that has an error value.: CurrentlJserHasCode( {Security\AlarmConfig} ) and CurrentUserHasGroup( {$2.@Area} + "_Advanced" )
Do the (raP-5_00-SE) Alarm-Faceplate only work with Pax v5 objects, not tag based alarms?
Good afternoon everyone. Just starting to use Logix based tag alarms, and I am likely a little confused. What I would like to do: Use Logix 33...
1,875
Hello, I have an application with a CLX L8 running under firmware V31 and an instance of FTView SE version 11. I configured a logix based...
2,062
I have a RS Logix 5000 program that i feel was poorly structured and I'm trying to make the best of it. There is a series of approx 40 tags with...
1,835
Hi all I've done a bit of a search and cannot seem to find anything. I'm exploring using the newer tag-based alarm functionality in the GuardLogix...
6,121
Hello all, I'm trying to use the Logix Designer SDK to upload and download a single ACD to many controllers. I got this to work fine copying...
81
