[Logix] MSG instruction giving 16#0005 error, not sure why
Is there a reason you can't just write the data from the ControlLogix?
I have not tried that. My main concern there is if I have a write failure too many times, it may cause a fault in the L73 controller which could affect all of my control systems (pretty much all inclusive) in my utilities plant. I am not sure of what a write failure would do in my primary system (L73 processor). IF I have read failures in the secondary system (L19ER processor) and it causes a fault, it only affects a single system.
I may give that a try and see how it goes.
127
Is it possible to configure the MSG instruction in CompactLogix to communicate with another CompactLogix in online mode or should the PLC be in...
1,441
I have two 1769-L32E Compact Logix PLC controllers. One the remote plc I have two msg instructions setup to read two separate ESD tags from the...
4,567
In the few examples that I have seen on AB's website, the MSG instruction is triggered continuously; as soon as it's done, it is re-triggered. It...
1,575
Hello all. I need some help setting up a MSG instruction to transmit 10 bits of data from a compact Logix processor to a micrologix 1400. I have...
31
20,216
