LCD vs LED
dear guys,
thank you for your feedback.
I have depicted several advantages of LED over LCD which contradicts with the one indicated in the attached comparison sheet
1- better contrast
2- higher resolution
3- energy efficient
4- longer lifespan
5- less strain to the eye
please advice if you agree
dear guys,
1- better contrast
3- energy efficient
4- longer lifespan
No, read the thread, as i said earlier your chart details LCD vs LED Matrix displays from years gone by, the part that say "by large number of LED beads, low resolution" gives this away among other things
What is it you are trying to do with this comparison ? Are you trying to convince somebody to buy a certain product ? Or is this some other type of exercise ?
If you need to supply a SCADA display just buy the size of monitor you need, they are all LCD with LED back lights, you cant buy anything else now unless you try VERY hard.....
hi tragically1969,
this comparison sheet was given to me by the contractor to check it, I feel he is cheating.... so I am trying to reply to him and show him that LED are in fact better than LCD
hi tragically1969,
What is it exactly your client has asked for ?
The chart is not a comparison between LCD and LED displays the way we are discussing or you are trying to prove, the chart is a comparison between LCD and LED matrix
LED matrix:
http://www.messagemaker.co.uk/large...iypWKbdRVwdp237QIWDqZhOINm5nHxthoCbvsQAvD_BwE
So in this context LED is not better than LCD as its lower res and requires more power and better cooling etc.
I think the problem is that the OP was not clear enough in his question or context, likely due to ignorance of the terminologies given from the "contractor".
From that chart, I surmise that the context the contractor is referring to is very very large "jumbo-tron" type display walls, where the image is created by vast amounts of somewhat large LEDs in panels, meant to be seen by large crowds from a distance; like this:
Pixelation becomes very apparent when close up and this technology is typically not suited for SCADA system monitors and HMIs.
This is versus a number of LCD screens arrayed to coordinate into a single image, like this:
Also not typically used for SCADA / HMI monitor applications, but it has been done for large facilities where people want a "big picture" view.
For SINGLE monitors / HMI displays, the terminologies are different.
"LCD Display" = LCD displays are "transmissive" in that the LCD elements BLOCK varying amounts of light with the liquid crystal, and that light is PRODUCED by something else. The original older LCD technology used CCFL (cold cathode fluorescent lamps) for the back lighting. Almost NO (high quality) industrial LCD monitors still use this technology, because as time wears on the CCFLs get dimmer and nobody likes that.
"LED Display" = is actually still an LCD display, but one that uses LEDs for the backlighting of the LCD elements. MOST industrial displays / HMIs now use this technology. Long life, low power use, vibration resistant etc. etc.
"Direct LED Displays" = LCD with LED backlighting, but each LCD element has an individual LED backlight directly behind it, as opposed to the original design that has the LEDs only on the sides, reflecting in, then back out through the LCD elements. Direct LED technology gives better contrast control, but costs a lot more.
OLED Displays = latest technology. They use individual "emmisive" LEDs to create the image, so no backlighting is needed at all. They consume less power so are better for battery powered things like tablets and phones, but the cost for large displays, like what you might see in a SCADA system, can be prohibitive. Only a few off-brand HMI manufacturers are using OLED technology for non-mobile HMIs, at least so far. But when they are battery powered, the lower power consumption overcomes the cost differential compared to the cost of increasing battery capacity or sacrificing up-time.
looking for a device that I can connect to a Wifi network and display a web page. so basically a tablet without all the other bloat software...
3,944
Is there something like a LCD or LED screen which can communicate with Allen Bradley PLC/SLC/MicroLogix 1400 via Ethernet? I want to display...
2,379
I got an Error 33 on a PanelView Micro 300. This is the "LCD RAM failed" message. Just wondering if anyone has every successfully recovered from...
3,364
Hi, I have two Toshiba G3 Tosvert-130, one of them I can see monitoring mode, I can control with the LCD display, recently I changed the presets...
354
I have a 5069-L320ERS2 that has the scrolling LCD screen on the front. Is there any way for me to see what message is being displayed on that...
1,779
