Inductive Automation-Ignition< Quick start
How do I get a UDT (PLC Datatype) from Siemens to Ignition 8.1?
Say I have a DB with different tags and at least one tag is based on a UDT, I can connect via OPC-UA to the DB and have access to the tags, but not the ones based on UDT.
Thanks Phrog30. I found the answer in S7-1200 manual. Structured data types are not supported along with arrays and a couple of others.
I'll have a closer read as it looks quite involved.
I'm new with ignition so no, I'm not sure, but it does look like Siemens OPC-UA server (driver-interface whatever you call it) does not support structured data. I think what they're referring to is the pre-Version 4.4 when every tag had to be created and indirectly addressed in ignition designer; versus now with V4.4 I setup an "interface" containing the tags I want to access and in ignition I can just drag and drop them.
But if that way (old way) works for UDTs then I may go that route, I'll check it out.
Are you sure?
https://forum.inductiveautomation.com/t/opc-ua-struct-data-type/26905
I don't deal with Siemens, so I can't help. But it could be worth your time either asking on the forum or calling your sales/tech rep and asking for assistance.
So I'm pleased to report that I was wrong and it is actually quite easy. I followed the thread you posted and in the process found it works much better now and I did not have to use indirect addressing. Ignition displayed the tags and all I had to do is select them and ignition assigned some strange looking URL looking address to it. It did not matter that they were from a UDT and the DB was also optimized.
So although these datatypes are not supported in the new drag and drop way, they're not that much work to connect to them.
Thanks Phrog30, much appreciated.
Inductive Automation is announcing Ignition 8.1 today at "virtual" ICC. I'll miss seeing everyone in California. Registration is free online. Big...
1,247
Inductive Automation Ignition unable to trend small numbers . Trending stops working below 5e -9 . 5e -9 = 0.000000005 . We are operating...
3,155
All, I know this type of question has been asked (and sometimes answered) ad infinitum but after looking I'm still stuck and could use some help...
19
6,353
Hello everybody, i wanted to check in with anyone here that has used Inductive Automation Ignition HMI software. Is it as good as it looks to...
4,803
Hello All, I am looking for a way to get the data/information from METASYS BAS of Johnson Controls. I would like to get this data into Inductive...
2,406
