Hydraulic Fluid Level Detection.
There's a lot of guesswork being done in these posts.
Here's another possibility. I have seen oil lubrication systems that pump out oil to lubricate large rotating tables and slides.
When the system starts, a large amount of oil is pumped out of the reservoir filling lines and bearing surfaces and then a steady state flow ensues as oil flows out and gravity feeds back.
When the system stops, all the oil slowly returns to tank.
Pressure is relatively low the entire time.
Maybe the OP will eventually get back and let us know what this system really is.
Hi, Does anyone have any experience with hydraulic fluid static electricity affecting electronics?
1,804
We are woking on a servo hydraulic system for investigating the dynamic behaviour of fluid flow in a piping systems. The system consist of a...
5,872
Hello everyone, I'm reaching out for assistance regarding a project I'm currently working on. Specifically, it involves a hydraulic system with...
459
Hi All, I could do with some advice on a hydraulic control system. It is necessary for me to accurately position a vertical hydraulic ram with...
34
2,022
Hi, I am about to start a project controlling a hydraulic ram using a Siemens S7-1200 controller. It will need to be quite steady control, by...
778
