How to upload Memory Card FEPROM to S7-300 315-2DP
joeyd11ph
Aug 2009
Qatar
Hi Group,
Please correct me if Im wrong.
Memory Card FEPROM serves as LOAD MEMORY that contains configuration file and user progam.
Since this is Flash Eprom it should retain its data in the event of power off 24V without backup battery.
QUESTION IS:
If I do a MRES it should upload its content (configuration file and user progam)into the work memory. If this is correct according to SIEMENS manual how come my CP342-5 still exibit SF and STOP LED always "ON" after MRES.
By the way this problem occured only after replacing the dead backup battery.
My setup is:
S7-300 > CPU 315-2DP (6ES7 315-3Fx-0AB0)
PROFIBUS CP342-5 (3425DA02-0XE0)
ASi CP343-2 (343-2AH00-0XA0)
MEMORY CARD MC951/128KB/5V FLASH
(6ES7951-0KG00-0AA0)
PC > CP5613 DP BASE (6GK1561-3AA00)
SOFTWARE ARE:
SIMATIC NET INDUSTRIAL COMMUNICATION PC/WINDOWS 05/2000 S79220-A5406-F000-01
COMPROFIBUS V3.3
COML7 V2.12
OPC SERVER
SETTING PG/PC
WINCC V5.1 S79220-A6045-F000-01
Hello everyone iam beginner user s7-300 , i need help procedure to upload completly BU prog in the cpu 313 or from memory card to my laptop...
2,238
Hi* I have a an Modicon M258 PLC and need to interrogate the program in order to find*what is wrong with the plant! How do I upload? I understand...
3,587
this is video, intruction upload memory plc omron http://goo.gl/ytbKyT http://goo.gl/180b1O http://goo.gl/R6dEsX
1,722
dear everybody please help me upload and download data memory plc mitsubishi how how is upload and download memory data plc mitsubishi ?? how...
3,806
Hi, The company I work for buy a machine that works(?) with a SLC150. I will change this PLC with a new one. So I need to upload the program...
4,614
