how to merge ladder diagrams on rslogix5000
timalg
Aug 2009
algiers
dear friend,
i use rslogix 5000.I have a program consisting of several ladder diagrams.is there a way to merge them in only one logic diagram to print it.
regards
I am not sure what you want to do. Can't you just select the rungs from one and paste into the other one?
Or if the tags are different, you can export the routine and import in the other one, it will copy the tags also (it will prompt you first)
If you are looking to print a rung here and a rung there, if there are not too many, perhaps the easiest way is to open MS Word. Then go to RSLogix/Studio, select ONE rung and do a copy. Then go to Word, right-click and select Paste Special, and paste the rung in as a bitmap.
The paste will auto-size the rung to fit the margins, which may make some complex rungfs seem to be in a smaller font than others.
HTH
dear friends,
thaks a lot for your help .to clarify as in the attachement document I want to merge between motor_start_stop and operation.
thqnks
Hello, besides a post on this site from 2016, I haven't seen any questions or answers regarding this. Is if it is possible to strip the RSLinx...
1,577
Is there a simple way to merge the description off line for RS 5000 Like RS 500 I am new to RS5000 and have several applications running that have...
1,079
I have 2 different .RSX (RSLinx configuration) files. I would like to make them one file. Is there any way to merge these files?
1,851
How do you merge off line a rs 5000 program with one that has descriptions on the tags. I have done rs 500 but never 5000
1,479
I am using a Modicon M340 PLC, with Unity Pro. I have two words. These two Word is part of one value. I need to merge these two Words and convert...
5,274
