help with a MELSEC FX2n PLC
backstage
Jan 2018
austin tx
Our theater’s house curtain controller has a Mitsubishi Melsec FX2n PLC in it that was installed back in ’02. The back up battery failed and of course the program was lost. I have the program on a back up thumb drive as well as a copy of the PLC editing software Medoc. Is this along with an old laptop running Win95 and the SC-09 adaptor cable all I need to reinstall the program? Thanks for any help
Theoretically you have all the necessary parts, as long as the cable has the adapter for mini-DIN connector (older cables for FX2C and earlier did not have it).
I recommend that you first execute a clear-all and if the project also has a copy of the data of the D's memory area also transfer it after having transferred the parameters and the program.
I would slightly disagree.
Reinstating data (D registers) can have unforseen consequences.
If they are saved in the program (highly unlikely) they would have been saved at a certain point in the automation.
No telling where that would be.
As for your setup.... win 95 needs a batch file to use the com ports.
Medoc is tricky to the uninitiated as it is a dos program.
You have all you need but good luck.
About D registers: All the data was lost with battery failure. If there is a copy of those registers in the project, that should be the starting point because it is the only one available. I still recommend that they be transferred ( if the project.dwr file exist)
If they were saved later versions then obviously he should use the more recent set.
I remember that Medoc still worked pretty well in Windows 95, the problems came later with the following versions of Windows.
The latest versions of Medoc, I believe it was v2.3 or 2.4 were also optimized for Windows and I remember having used them on Windows XP without major problems.
Good luck !
I mean the battery backed D registers that can contain configuration values.
On the FX2n file registers occupy the same area that D battery backed registers: from D1000 to D7999
Melsec Medoc does not save D registers automatically. It is a separate procedure, which creates a .dwr file. If there is no such, there is no data backup. The logic, however, may be not relying on any non-volatile data in the registers.
Also, Medoc has no ability to save the latched M bits status. I there are such in the logic, they will have to be properly set manually.
Hi, I didnt thought i would come across an A1N CPU in my life. But now i have and it is as i thought programmed in MEDOC 2.4.🙃 Is it...
2,993
I have the unfortunate duty to test an AD71 positioning module..the problem I'm having is the test setup in the manual for the drive I'm using...
1,718
Hi, I'm new to the melsec system and I need to install CC links on some processing equipment. I have no ideal how to address the CC link cards or...
3,822
I want to reset a bunch of memories in my program and I was looking for a zonereset function but can't seem to find one. The FMOV function only...
2,282
Hi guys I have installed GX Simulator into its default installation folder/directory. Which i am having trouble finding where the .exe file for...
6,035
