Help! Beginner PLC question
rhysplc
Jul 2021
Leeds
Hi all,
this is my first thread on here, completely new to plc. Have been given a 1769 L24ER QB1B to play with.
I have a PA2 power supply and a few I/O modules in the rack, (Photo attached)
I have RSlinx and studio 5000, Factory talk me.
The problem I have is when I switch on the 1769-PA2 power supply, I cannot get any LEDs to light on the controller itself, therefore cannot connect it to rslinx and practice downloading some programs to the plc.
I have run 2 cables from the power supply (PWR OUT+24Vdc) to the +24vdc on the controller and likewise with the COM wire but still no power.
Hopefully a schoolboy error someone can point out!
thanks in advance.
Remove the 1769-PA2 and all of the expansion modules.
Install the end cap.
Apply 24VDC to the processor and see if it boots up.
There are limits to the number of I/O modules
From the manual: IMPORTANT Remember the following when using the embedded I/O modules on CompactLogix 5370 L2 controllers:
• 1769-L24ER-QB1B controller - The digital input points and digital output points are on one embedded I/O module.
Therefore, the 1769-L24ER-QB1B controller is considered to have one embedded I/O module.
• 1769-L24ER-QBFC1B and 1769-L27ERM-QBFC1B controllers - The digital input points and digital output points are on one
embedded I/O module. The high-speed counter module input/output points, universal analog input points, and analog
output points are on another single embedded I/O module. Therefore, the 1769-L24ER-QBFC1B and 1769-L27ERM-QBFC1B
controllers are considered to have two embedded I/O modules.
Yeah, those processors have an embedded power supply and will supply power to the IO modules themselves. You should use a standalone 24DC supply to supply the processor as TWS indicated.
So to start off: I have no experience with PLC's, but I'm good at figuring stuff out, but I need some help to know if my PLC is just dead in the...
122
hello everyone, I have a siemens s7-1200 that is dismantle from a worksite. I want to learn writing program. however, it's locked and need a...
1,937
Hello everyone, I'm really interested in playing with PLCs, i'm thinking of picking up a TECO GENIE II SG2, its relatively inexpensive. As for the...
3,463
First I'm am using the logixpro trial version form the learning pit. I'm having some problems with a program. I need some help. It would be...
2,935
Hi ppl, I've just finished my second year studying Electronic & Computer Engineering @ Uni, in the UK. During summer, i'm involved in an...
5,777
