Has anyone here used OPC XML gateway before?
Hello,
If by connections you mean tags (data points) then PeakHMI can handle 2000 tags.
Good luck,
Mark
http://www.peakhmi.com/
2000 tags in HMI (RSVIEW for example).
need to connect to OPC-XML Server.
now, the HMI's OPC client can't connect directly to OPC-XML Server. that why i need the gateway.
i tried XGate/XCom but it doesnt work...
As far as I know, OPC-XML is less performant than OPC-DA.
Most HMI's support OPC-DA, RSView does for sure.
THe Kassl gateway looks interesting, but it looks as the limit is 130 reads or writes per second. See this benchmark:
http://www.dopc.kassl.de/xgatebm/
I am certain the OPC-DA can do lot more than that. Not sure what is the limit though.
The real question should be:
What is it in the other end that requires OPC-XML ?
OPC-XML Server.
No need for DCOM configuration for the client and provides opc web services as well.
faster Poll rate isn't important. can be even more than a minute.
Any news ?
I am interested in how you will crack this nut.
If someone has written a spec for you to follow, then that someone should also describe how you shall achieve the required functionality.
I am guessing that it is simply not possible.
Hey guys, One of my clients sent in their rotameter for their V10K chlorinator in for refurbishment, and now that it's back and re-installed...
1,589
17
4,559
I will soon start working on an application which will require communicating with an OCS CheckWeighters to an Allen Bradley PLC model SLC-5/05...
1,709
Apparently, they are not compatible and i was hoping there was a work around.
694
I've been getting some advertising related to the attractively packaged Wago Compact Controller, model CC100, lately. As far as I can tell it's a...
2,234
