Has anyone heard of / used the CompoNet protocol?
I believe it is a high speed industrial communications CIP protocol similar to DeviceNet's Master/Slave hierarchy with Allocate/Release tokens for each transferred I/O packet; it also has a 'pre-allocated' data transfer methodology similar to the ControlNet 'scheduling', however, it has the capability to 'Release' connections which are no longer needed and has only a 'polled' type data exchange mechanism.
CompoNet is running on a proprietary physical layer.
9.3.4 of
https://books.google.com/books?id=p...HRSSB1wQ6AEIVTAJ#v=onepage&q=CompoNet&f=false
Omron is implementing it quite extensively; I have never personally been around any implementations though; most likely Ken did...:D
https://www.ia.omron.com/products/category/automation-systems/networks/componet/
It is basically an update to Omron's old CompoBus 2 wire remote system and has been made open and is administered by ODVA. It is fast, reliable and runs on a twisted pair. There is a heap of error checking built in and it is capable of explicit messaging although I do not know of a manufacturer that has implemented that at all. I have used it extensively for remote I/O control on Omron PLCs. It is also fast - 1000 digital I/O over 30 metres on a twisted pair update time is I believe 1 millisecond - faster that the PLC scan time usually. By the way the physical set up is far less demanding than DeviceNet and the system is no where near as fussy and cranky either.
Hi guys, Been asked to look at an existing well system. It's very simple, there is a pressure transducer at the storage tank that provides a...
2,294
http://stripchartopc.com/index.html A coworker found this while googling around. It is a trending package and it looks very handy. However, I've...
1,730
Apparently, they are not compatible and i was hoping there was a work around.
694
I've been getting some advertising related to the attractively packaged Wago Compact Controller, model CC100, lately. As far as I can tell it's a...
2,235
At our facility we have some strange behavior from one of our ControlLogix PLCs. It runs three palletizers. We have had some rare but very...
1,600
