Has any used a ballistic pressure transducer with a PLC?
I am not sure if it will capture the event that I need to use as a control.
The device that I an using is a PCB Piezotronics ICP ballistic pressure transducer when I use LabView with a DAQ device running at 25khz I can see the signal I just don’t know if I will see it with a BRX PLC with analog input will be able to see and process quick enough.
Thank you
Thank you
