Function Block not inputting the correct values
Can you post couple screenshots and exported function block.
Without more info it will be difficult to say anything
We managed to figure out what the issue was. For some reason when we copied the DFBs it didnt create new instances of them. So regardless of the tags into the blocks being different, there was multiple blocks called "generic_alarm_1" So internal tags were overwriting each other
Hi, I have attached herewith one image which our programmer has been used in S7 1500 PLC. Now we need to use the same instructions in S7 1200 PLC...
131
Please see attached file. I need this program in Function Block form but I am totally lost on this. Any help would be appreciated. Thanks!
306
Hi! I am using a TM200CE40T PLC from Schneider to write data over Modbus. I have used Memory words (%MW) before using the Write variable...
542
Hi folks. New to the forum, but been working with PLCs for several years now. Would like some advice on whether you would keep this logic, or...
1,074
Hi Yes, I'm stuck again. Trying to define a Function Block. What I've put in there so far has been a straight copy/paste from the code (and that...
22
2,928
