Fanuc CNC Communication Failure
J_Bruno
Mar 2024
El Salvador
I have a CNC cutting equipment, all the components are Fanuc from the CNC CPU A02B-0307-B822, a PLC AIF01A and a panel i, on the panel i (operator panel) I get the alarm error "SV5136: Number of amplifiers not enough" I check my op amps and they all show on the status LED "-" (dash), my CNC shows "0" (zero), also on my i panel it shows me "SW Not Ok".
Also my PLC does not show any active output, I have to assume that because I do not have communication in the PLC
I have checked the fiber optic cable that communicates the CNC with the amplifiers, everything seems to be connected correctly and working in terms of the fiber optics.
I would like to receive suggestions as to what could be my problem.
Either Someone has messed with your servo parameters or your FSSB connection is bad.
You may get more help at cnczone.com, due to this being a cnc.
This has nothing to do with your PLC. Fssb is not your comms for the plc, it is the comms for the servos.
Hi all. I am wondering if anyone connected the FactoryTalk to collect data from a CNC, specifically FANUC. I know my way around several SCADA...
5,084
Hi, guys, how you doing? We have one FANUC Series oi-MF CNC machine and plan to back up all data to a USB. There is a Fanuc all data backup...
1,622
Hi, Can anyone help me to get more information on Fanuc CNC 31i B5 series? The below is the official link to the CNC model...
1,504
Proface HMI and Fanuc CNC communication is possible or not
2,567
Gentlemen, I have been trying to bring back a Fanuc PowerMate "H" back from the dead. I am now wondering if there is a upgrade path that can...
2,756
