factorytalk viewpoint mobile info/ research help
stu
Aug 2005
England
786
Hi guys
The other day I saw a youtube video on factorytalk viewpoint mobile and I thought this would help our engineers on dianostic on the machines via an ipad
, but as I have never seen it work or know what it can do ,has anyone had the joy in programming this or installing, I'm after info see what I need thanks stu
I don't know about FactoryTalk, but I do this same thing with AdvancedHMI. I connect a common wireless router to the PLC network (use AccessPoint mode if PLC already has a fixed IP address), then use the wireless to connect a tablet to the network. I will then put an application on the tablet that communicates to the PLC. AdvancedHMI will not run on an iPad, but it is very easy to find Windows 8/10 tablets starting at around $100USD.
I actually just did this the other day when a machine had an intermittent switch in a location that was not possible to see the PLC indicators or light on the switch. It only took a couple minutes to create an application with 2 BasicIndicators that displayed the status of the switch inputs. I put the application on the tablet then let the maintenance guy put it in his direct view as he tracked down a bad wire that had an intermittent break.
A wireless tablet makes a very powerful troubleshooting tool.
Hi all, I am facing some issues with the factorytalk viewpoint. I have this string tag in PLC which can be read from FTView SCADA. The display...
1,104
Hi, my factorytalk viewpoint is not displaying any data relating to tags on my plc. They display fine on my client which is on the same host...
4,213
Hello again, We are working on a system that we developed and had been working fine for years. Recently, the customer decided that they needed to...
1,725
My goal is to be able to have an HMI as well as a Status Monitor (a TV that shows what machines are down, percentage of cylce time, etc.). The...
2,188
Hello, I have a SE application that I am using FactoryTalk ViewPoint on. Is there a way to do security logins for button use with ViewPoint...
2,474
