FactoryTalk View ME - Global Object with Goto Display Button
hafizzz_ahmad
Apr 2024
Juru
Hello, I'm using FactoryTalk View ME V10.
I created a valve as a global object with multiple parameters and when the object is being used at the main screen, we just need to enter the tag at the Global Object parameter values (see attached image).
This works perfectly.
So I wanted to add a Goto Display button to the Valve global object, so that when operator clicks it, it will open up a faceplate.
Unfortunately the button does not work.
So my question is there anyone has any success doing this? As of now, I'm doing it one by one where I use the Valve at the main screen, then I add the Goto Display button on top of it.
See attached pictures of the properties.
I am using a Global Object Touch animation to open up a popup window. Can you use one of the Parameters you pass though to adjust the visibility...
3,198
I’m trying to use two string parameters as a title. I have a caption like: /*LS:0 {#100#101}*/ If #100 = Cat and #101 = Dog I get “#100Dog” Not...
2,249
V 10.00.01 Patch 9 Is there a good way to get the child Global Objects to update? It seems whenever I make a change like moving an object (text...
10,045
V 10.00.01 Patch 6 Is there a good way to hide unused values or objects inside a Global object? I have a number of pumps and rather than creating...
6,310
V 10.00.01 Patch 6 Having a bit of a tiff with View SE. Ideally there would be a memory tag or parameters file with a color value that could be...
3,254
