FactoryTalk HMI Question (Recipes)
Foxtrot2050
Feb 2024
OHIO
19
Good morning!
Let me start by saying, I am still learning about this type of HMI programming. I recently watched a video about recipes and how it was created. I got most of this to work but I am missing something. What I am trying to do is have them able to select a job # then when they do that I will have it auto populate a style number to the PLC for the Robot.
Currently I have a Tag in the PLC Style_Number.
If I am doing this correctly I don't want anymore ingredients because all I want to do it change the Style number.
The problem I am having is there is 200 jobs with different style numbers. (Job 1 = Style 1 etc.) As attached if I change TEST 1 value it also changes TEST 2 and TEST 3 it isn't all separated settings. The only way I got this to work for for up to 2 jobs is make the data set 2 but can you make more data sets or am I doing this in the wrong was. Hopefully this makes sense, if you need more information please ask.
Are you only changing the {[PLC]Style_Number} tag and have no other parameters for your recipe? And if that is the case may I suggest using a list selector instead of a recipe selector?
The main difference would be that recipes are meant more for large amounts of variables as opposed to just one tag. I’m sure that you can use a recipe select for your application but it would be more time consuming to set up.
If you look under objects find “control list selector” I believe that it’s under the advanced tab.
Then make your List selector, under properties set how many states that you want, then under states you can give each state a name and value. I.e. Style 1 value 1 Style 2 value 2 etc.
In the connections tab I normally set my value to a different tag (style list select or something of that nature), then under enter I would make another tag that’s a bool (style select enter etc)
Then in your plc XIC (the enter bool’s tag) ONS then a MOV (list selector tag) to {[PLC]Style_ Number}
I have a PanelView 6+ that runs a ME program. Recently, I've had a couple occasions where the HMI graphics has question marks all over the...
1,682
Hi, I wanted to ask is there a way to have a visibility expression use the IP address of the HMI (Dynics, not PV) to show certain elements? The...
233
Hey everyone and anyone that can lend a helping hand. I have a project that I am being asked to add some animations of Solidworks or "3D" models...
408
Hello, I have a CNG compressor that is run by a PLC. I tried to get team viewer on it to be able to view it remotely, I accidently disabled the...
125
Hello everyone, I am a student and would like to take the next step and learn FactoryTalk (Batch preferably) and how to create HMIs etc. Would...
519
