Ethernet vs Profinet cables?
Rson
Jun 2017
Michigan
521
Is there really any difference?
I see the ethernet are typically colored teal and the profinet green. They appear to have the same pinouts - and I assume a standard CAT5 ethernet cable from Staples would work in either case, correct?
Sorry if I'm not clear:
If I have a teal Ethernet/IP cable and I use it in place of a Green Profinet cable for a Siemens install - there really isn't any difference apart from the color of the sheath, correct?
You want a minimum of Cat5E STP if you aren't using the normal cable(green stuff).
6 or 6e is probably better, and pick stranded or solid based on how it will be installed.
Cable is cheap, installing/repairing it is not.
Will wokr fine...
Just make sure you get good quality shielded Ethernet Cable, CAT5E or better.
The "E" means high speed (1000 Mbit / 1 Gbit) cable. After CAT5E, CAT6 and above are already high speed rated.
I use this for my Profinet long runs... where I add good quality ("feed Thru" type) connectors
https://www.automationdirect.com/adc/shopping/catalog/cables/bulk_multi-conductor_cable/continuous_flexing_profinet_cable/q5099-1
For short runs:
https://www.automationdirect.com/adc/shopping/catalog/cables/cat5e_patch_cables_(2_to_50_ft.)/cat5e_patch_cables_(shielded_twisted_pair)#
Officially, I think PN uses a different standard than Cat5/6/whatever to approve cables (because of course they do), but it's still an ethernet cable. Same pinouts, etc. Note that PN cables are typically 2 pair instead of 4 pair, because most PN devices are only 100mbit, but you probably want 4 pair/gig rated cable for backbone stuff.
Realistically, yes, it's probably fine, as long as its shielded.
The green Profinet cable is shielded, has only 4 conductors, uses different colors, and has higher voltage rated insulation than standard commercial CAT5E or CAT6. Profinet cable only supports 10/100Mb connections, and does not support gigabit.
spring caged connectors don't work with solid wire very well. Vampire type connectors work well with stranded. Keep this in mind with the connectors your using with your cable, it factors in for a good connection.
You can not make a short radius bend with the green cable, all of the bends will need to be a long radius 90's, its like they are made with a stiff PVC jacket
The ends are huge... the middle one is a cat7 the other is a cat5
Only the orange and green pair are used for 10BASE-T/100BASE-T Ethernet connections. 1000BASE-T and higher also use the blue and brown pair. The "spare" pairs may also be used for POE (Power Over Ethernet) applications, such as network cameras.
The same with ethercat cable. This could be a green cable as well and the ones i have used have a bend radius that is pretty good.
I have used cables that are called ethercat, for hooking up my laptop to ethernet PLCs.
...the middle one is a cat7 the other is a cat5
Cat 7 is not an official specification, but rather a manufacturer-declared rating, is that correct?
The foil stamped on the outside of the plug head provides a shield connection. I discovered this one day by inadvertently rebooting a Rockwell HMI multiple times. Apparently the control panel and my laptop had enough of a potential difference to bring the HMI's voltage to an unusable level.
CAT5E, 4 wire, shielded, voltage and EMC approved for industrial use.
Equally important is to use good connectors. You need to check that the chosen connector works well with the chosen cable.
The connector must be able to get good contact with the wires and also the screen. The connector should also grab or bite into the cable mantle to get a good mechanical hold onto the cable. If the wire or cable diameters are different than what the connector is designed for, then it will be unreliable and fail in the long run.
If you purchase the combination of connector and cable from a reputable industrial vendor, and that it is stated that the cable and connector are suitable for each other then you should be covered.
Btw. whoever invented RJ45 should drawn and quartered.
173
Hi, Usually would use Anybus which are easy to set up, however they are struggling to supply them to us, so looking at other alternatives. Do...
1,759
I am trying to setup communication between two Siemens PNPN couplers and a CLX on Ethernet/IP. I have deployed a Prosoft PLX82 gateway to handle...
2,333
I have a machine that has a Siemens PLC CPU 315-2 PN/DP. It has numerous remote units on profinet using a 192.168.0.x network range. Is it...
2,681
Hi there, I have an application where I’m required to connect Siemens S7-300 PLC (Profinet) to Allen Bradley Control Logix Remote I/O Rack &...
3,671
