eror run Cpu Mits Qseries
arif.ae
May 2014
Tangerang
We have eror run for cpu module. The led status for run is green flash. We try to reset cpu modul and run again, the result is still same. Please help,thank you.
Thanks Mr. Iant
I've Run the CPU diagnostics and appeared operation error. I also had to run the system monitor, and there is an indicator on the CPU module error (Orange block).I reset manually from the Cpu and at the time stop position we have write a back up program to plc then we try to run mode and result red flash from eror indicator,I tried many times, sometimes eror led off,but the run indicator is green flash.
Regards
Arif H
Got a fault on an SLC5/05 says "A rack data error is detected. Check slot 8". Slot 8 is a 1746-NI16V (16 channel voltage analog input) Is the...
1,596
Can any body help me... i using S7200 in one of my project...in that i also using PT100 sensor and temp.transmeater and analoge i/p cartd...
1,295
Hi, i am using DVP-14SS2 PLC, after program written to plc, when power is reset, plc doesn't run. always need to connect to pc for the run mode.
40
Hello..I am new to Plc.I have Mitsubishi Melsec Fx3Ga-40MR PLC controlling a machine for packing powder.Currently the Plc has issue which power...
164
I'm looking to get some spare keys for this PLC. Does anyone know a source or have a part number? My searches are turning up nothing at the moment.
100
