Email and SMS Text set up for Compactlogix
Abner300wsm
Jan 2015
Georgia
I am working on implementing a new system at our plant that needs to send emails and text messages to on call employees. The controller i will be using is an Allen Bradley 1769-L18ER-BB1B. I have found some good info on the knowledge base on how to set up the program to accomplish this. The question that i have is the network side of this. What steps need to be taken to set up the network to accomplish this?
I just did a project to send email messages. The following link is from Google to send a message using SMTP without authentication. The catch is that you must send only to a google account. However you can then use the forward email filters to send the message on.
https://support.google.com/a/answer/176600?hl=en
This can be accomplished without to much interference on your network. You only need access to the internet.
Most PLC's do not handle authentication well. If you need to use SSL, then I would look at stunnel.
https://www.stunnel.org/index.html
Hope this helps,
Garry
http://www.accautomation.ca
Hello, I am seeking guidance on configuring my Rockwell Allen-Bradley PLC logic to enable SMS sending through my Secomea module. While I have...
381
Well, carriers (Verizon specifically) are starting to blacklist email to sms messages. Of course, if you pay Verizon $100/mo they will white list...
3,681
I am having problems trying to get either the SMS or Email to work. I have read every post on here and else where and do not have a tech connect...
3,286
There is a Cellular company, requiring to send data (event triggered) to a single Monitoring station from thier several hundred Signal towers in...
1,553
Can anyone help out with this Panelview Plus Performance Email. I keep getting an "unable to activate connection "smtp-mail.outlook.com". I've...
235
