Does 1768-ENBT/A Rev. 2.3 Supports MSG instruction?
asteroide
Jul 2010
der
158
Hello Friends
I am trying to connect to a Zebra printer. I can print the label with hyperterminal both by RS232 and TCP/IP.
Now, I am trying to send de label from the PLC through Ethernet, but when Create sockets a message appears: Error processing connection related service.
I have read several post and tried different things but the error continues.
The hardware is:
1768-L45 Revision 17.4
1768-ENBT/A Revision 2.3
Is 1768-ENBT capable of sockets connections? Should I update the firmware? In this case also I should update the CPU firmware.
O what else could I do?
Thanks in advance
According to the technote IN37624 (Access Level Techconnect) ver 1.002 or higher is required.
Based on your screenshot, I suspect that you did not set path correctly. It's pointing to the Slot 3.
Don't know what do you have in your chassis, but module next to the processor is Slot 1.
If you have ENBT module in IO configuration, then it would show the module name instead.
The 1768-ENBT/A is in the slot 1, slot 0 CPU, In the communications tab, If I browse for the ethernet card and select the name of the card, after close the path is shown like 1,3.
If I change the path to 1,1 and select apply, it is accepted, but when I open again the communications tab path 1,3 is shown.
I don’t know who wrote your code but is obvious that code is overwriting the message path.
The code is from AB, a couple of years I used in a Domino Printer, now I am reusing for a Zebra Printer. (just 2 small routines)
You were right, a tag was overwriting the path. Now it is shown correctly. 😄
Now, I have another error message, I have changed some options but without sucess.
Error Code 16#0005 Class or instance not supported.
What else can I do?
Thanks again.
Oh, wait, 1768-ENBT does not support sockets at all. I got confused with 1769-EWEB module that supports sockets. Sorry.
Hi I have a ifix 5.5 application where the operator opens a valve by clicking on a screen object. I can trace from object to data base that it is...
63
Hi, i am using DVP-14SS2 PLC, after program written to plc, when power is reset, plc doesn't run. always need to connect to pc for the run mode.
60
I am trying to connect with a Schneider plc which has a firmware version only available in Somachine v4.2. In Machine expert After taking upload...
134
They are installed in a control panel that was made in France and are intended for the termination of analog inputs. Each of the red capped...
446
