Displaying weight in hmi
advmin
Mar 2023
Sheffield
59
Hello Folks,
plc : micrologix 1500
The analog output from the loadcell is given to the plc.
Using the SCP function I have scaled it into an output float.
I want to display the weight in the float to an HMI screen.
1. Which output function(destination) should I use in the program to move this value for mapping that destination to HMI?
cheers.
It is good that you supplied the PLC information, but more important is the need to know the HMI you are using. Most HMIs nowadays allow you to read the PLC memory directly, rather than having to send the data to the HMI.
Hey everyone and anyone that can lend a helping hand. I have a project that I am being asked to add some animations of Solidworks or "3D" models...
421
Using FTview ME to create an HMI screen. Simplest task is giving me trouble. How do I create an HMI tag that will allow the name of the current...
165
Hi Everyone, I am hoping a Red Lion Expert can point me in the right direction. I am experimenting with data logging on a CR3000 10" screen...
632
I’m a bit stuck on HMI (KTP-1200) programming… See the picture attached. The PASS or FAIL box should only appear when the toggle switch is...
1,121
I have 6 Red Lion DSP units displaying PLC strings and data to 6 industrial LED screens. After sending the .cd3 file from screen 2 to screen 6...
1,054
